S
spacely
Guest
I wanted to use the macro recorder to capture splitting a spline at 0,0,0 using edit-curve-divide (in NX7.5.5). But the selection of the curve records a mouse click event, which never works again in playback since a different curve is in a new location. Is there some way to select the curve with other than a mouse click while recording the macro? I did try ctrl+A...it's greyed out.
Otherwise, maybe I can do this using a different language which I can run...but it would be between macro playbacks since there is more than dividing a curve I need to do.
Any help appreciated! Thank you.
Dave
Dave
