edit a RMB menu
moog3
Marine/Ocean
Nov 29, 2022
68
Can someone help me to find where the files are that control the RMB menu's.
The one I'm talking about is, In modelling if you hover over a body and hit RMB, you see a small menu with "hide" and "delete"
Also if you pick a body, and hit RMB, you get the same menu...
Sometimes it has other recently used icons as well, and also is sometimes accompanied with another menu, depending.....
I want to add the "remove perameters" to that quick access menu, but can't find where its controlled, or what name it might have within the interface.
Open a part file that has the type of object you are interested in. Open the customize command and switch to the "shortcuts" page. Select the object in the graphics window and the shortcut toolbar will appear for that object, you can modify the toolbar as desired. In your particular case, I think you can just select "All features" in the dialog list and customize the toolbar to add the "remove parameters" command.
www.nxjournaling.com
Oh that was easy, thanks.... It seems though, that remove perameters is a Modelling command, so I couldn't get it to work on sheet metal.
I wonder.... could I include it in the sheetmetal toolbar files to make it available in that module? (probably not)
