Buleeek
- Sep 5, 2017
- 98
I have an isolated footing and need to calculate maximum soil bearing pressure. The footing has a column offset as shown in the attached picture. In addition there is a moment. My question is, what "e" should I take into consideration? Should I just combine "e" from M/P and "e" from column offset?
And then, what is the formula for qmax assuming that e > B/6 (see attached)?
Please advise. Thank you
