Dear all,
long time no see, I've been not just busy, but overwhelmed by work lately since the rebuilding of the Italian city of L'Aquila after the April earthquake is starting. Among miriads of difficulties of course.
And I beg your pardon this time for posing a question related to soil mechanics rather than providing links to Jazz videoclips.
An engineer came out with this project of auger type anchors to be drilled into soft organic clays. That's to stabilize a wind-tower's foundation.
Now my doubt is how do I figure pull out resistance?
Auger will compress the clay on one side, will remold it on the other, so I envisage two opposing phenomena.
My gut feeling is to apply lateral friction (Su)to the cylinder materialized by the anchor's outer diameter. The soil cylinder should in fact fail as a whole and that's obvious.
But, which range of the in situ Su to apply, from residual-remolded to in site (Su 'undisturbed' is in the range of 50 kPa). IF the two opposing phenomena will balance out, nominal, in situ Su might just be the proper parameter to apply.
Any other aspects I'm not aware of?
This is still in the prelimiary stages, what's required is the minimum anchor's lenght, what I know now the design pull force ranges from 12 to 55 kN.
All other considerations related to the Eurocode provisions are to be developed after the proper method to calculate the anchor's resistance has been decided
