e-drawings for WF4
  • Thread starter Thread starter harichennai
  • Start date Start date
H
harichennai
Guest
Hi all,
Is any one out there using e-drawings for WF4?
From PTC site, I see it is a paid software. They give frfee download and give a trial period of 15 days.
We were uisng e-drawings successfully for Pro E 2001.
Thanks & Regards
Hari
You are correct.(I'm using it with WF4)
You must Pay if you want to be able to output to E-Drawings from WF4.
Another option you may like is saving as a 3D PDF. WF4 is the first version that can do this.
The good thing about this is all you need to read it is adobe FREE reader.
The bad is that without adobe 3D it is hard to control the size of the output file.
I think you will agree that Adobe acrobat read has a much larger base the E-Drawings. In the long run it will become the standard.
This being said the output process is far from clean at this point.
I hope this helps you.
