Dxf to Solid Woks
  • Thread starter Thread starter quasifun
  • Start date Start date
Q
quasifun
Guest
I'm trying to import a dxf file to Solid Works. I can get it to show up in the Solid Works sketcher but it's about 1/10 the size it should be. How can I import it to the correct size? Or can I scale it to the correct size?
Here is the method I use (my notes):
Choose face or plane where dxf will be placed.
Choose "insert"/dxf/dwg....
Browse to proper drawing...
Must be a Wblocked dxf (AutoCAD 2007LT)
Click finish.
I have done this many times and this is the first time I've had trouble with it.
Any ideas?
First, check, in AUTOCAD, if the dxf file is ok. Make a measurement in AUTOCAD and be sure that the measure is what you espect.
!!!!! NOT only look at the dimensions in AUTOCAD. Perform a NEW measurement and delete it after you check the result.
Good luck !
Mihail
Edited by: Mihail
I drew the original dxf myself. The dimensions are correct. I don't believe the file to be corrupt. I have resaved it as different names and tryied to import again.
I figured it out. When I imported this dxf, I hit "Finish". On this one I had to hit "Next" And change the MM/Inches setting. I feel like a..............
:) You are welcome any time.
