Duplx 2205 vs XM-19 (nitronic 50)
Johnwoo1991
Materials
IT
Is 2205 duplex (uns s31803) harder to machine than austenitic satinless steel xm-19 (uns s20910)? Are they pretty much equal for corrosion resistance?
Are they both annealed?
If so then I would suspect that 2205 will machine better than Nit50.
The Nitronic will work harden a lot in machining which makes life difficult.
2205 has noticeably better pitting resistance than Nit50.
We are looking at a PREn of about 31.5 for Nit50 and 34 for 2205.
Yes, both annealed. I assume that in the "as rolled" condition, or the strain hardened condition (as per Astm A479) machinability could be even worse for xm-19.
Would you consider superduplex grades such as F55 and F53 on the par with standard duplex 2205 grade as for machinability or worse due to higher nickel and molybdenum content?
Actually it should machine better if it was harder.
It would work harden less when being machined.
But it take a lot of hp to cut this material.
