Hi all. So Im hoping that Im writeing in the right topic.
I have a problem with converting .drw to .dxf. In .dxf all me dimensions all wrong. Can someone help me please with it?
Could you explain what do u mean by: "all dimensions are wrong"
--how did you checked that DXF dimensions are wrong (by opening in pro-E or any other software)
Explain in detail to help others help u
by that i mean that in pro engineer the dimensions were 300×100 mm when it was .drw, than I convertet it to .dxf for AutoCAD. But in AutoCAD (black dimensions) are not the same as in Pro/E.
EDIT: ok it is showing me it the INCH not in mm in AutoCAD. Haw can i change that?
If your drawing units are already set to mm (drawing_unit
mm), then do the following...
Open a new sheet in Proe
Set the sheet scale to 1:1
Input the views
Export the sheet to Dxf in AutoCAD Modelspace.
Do not Insert the Dxf file instead OPEN it.
Your drawing should read correctly.
Proe convert the views asit is to autocad. Ie if the view is in metric and 1:1 in size Proe converts it as the same. So first make sure Ur units and scale is as you required.
BEfore opening the DXF make sure Ur unit is set correct. U can check this by entering the command UNITS in autocad.
after opening the dxf to confirm your drawing size just type DIST(distance) and measure the distance (this will give you the real value. )
