Driving Component Parameters by Fam Table
  • Thread starter Thread starter dakeb
  • Start date Start date
D
dakeb
Guest
WF5
I have an assembly that has two family table driven states. In thesecond state a number of dimensions are altered to show components ofthe assembly in different positions.
Now, I am struggling with a compression spring component.
The dimensions of the spring are driven by relations and parameters.
There is a LENGTH parameter in the spring componentI want to modify in the Assembly Family Table.
I have tried asssembling it as both a rigid or flexible component but no way can I find a way to drive the componentLENGTH parameter from the family table. If I go into the family tabe and add a column I can select a parameter button,but that shows assembly parameters only. If I change to component parameters from within that window and select the spring, no parameters show up in the table.
As a flexible component I can alter the length by modifying the parameter, but it alters to the same flexed dimension in both family table instances.
Hope someobdy can help.
Dave
