moose_head27
- Jan 7, 2019
- 3
Hi, I'm looking to get opinions regards holes drilled through studs. The Ontario building Code states that holes can be drilled in load bearing studs up to 1/3 of the studs depth. I've looked at a home which 45% of the studs depth was drilled (2.5 inch hole drilled in a 2x6 stud. Just going by this statement alone would make me think this would not meet code. But I was talking to a co-worker about the minimum size of the stud wall for this application(residential). Code states we could use 2x4's which results in at nearly 2 1/3'' of the stud must not be drilled. Going back to the 2x6, 3 inches of the depth is un-drilled. So wouldn't it suffice since the wall is over-built? I'm not aware of these type of exceptions but it makes sense that it should be allowable.
let me know your thoughts.
