Drawing (Exporting from Proe to Autocad)
  • Thread starter Thread starter naveenrapheal
  • Start date Start date
N
naveenrapheal
Guest
Hi friends
I have a doubt in exporting pro/e drawing to Autocad.Even after keeping units in mm in proe (both in Part and in Drawing).iam not getting the 1:1scale in cad ,even after setting cad units as mm.will the drawing sheet size(drawing mode) and the scales matter?.
The drawings which i exported from proe will be made 1:1 in cad after scaling.i don't want that.i want 1:1 scale as found in Pro/e.
If I remember correctly, autoCAD doesn't have units, it has values. So you'll have to scale your model accordingly prior to converting the pro/e drawing/model into autocad.
I'd set up a mapkey to save time doing this.
There are config options that you should check before exporting into Autocad
dxf_out_scale_views
dxf_out_drawing_scale
auto_associate_dimensions
check these config options to yes and you will get a 1:1 every time even if in metric I do it all the time
good luck
Thank you
dxf_out_scale_views
good luck
This information was a lifesaver, thanks!!
