Draw Toolbar Question, Soldid Works 2015
  • Thread starter Thread starter phobos77
  • Start date Start date
P
phobos77
Guest
Who can help me with the following problem?
For a long time I have been using Solidworks 2012 en recently switched to 2015.
When I try to draw ie. a circle I use the Draw Toolbar, to draw multiple circles after every circle I have to go back to the toolbar and click the circle icon.
This is not what I am used to in version 2012.
This is not only for circles but also squares and lines and even with smart dimension.
Is this a simple configuration issue or does sombody have the same experience?
With regards,
Peter
I have found the solution: System options/ general/ single commant per pick.....uncheck
Can be found on the second line of the general page.
