E
EZ-now
Guest
Hi there,
I have a double (two way opening) hinge. Both axes open to 180deg.
I can't work out how to prevent the both axes from opening at the same time and the hinge becoming elongated. I'm sure that it is a simple amalgamation of Mates but I can't figure it.
I have the hinge axes mated as Hinge Mates including a 180deg range limit and have tried using path mates with the vertices on both the outside hinge plates and the inside hinge plate with a vise versa for the paths.
Cheers
EZ
Cheers
EZ
