Do PVSV and PRV on top of Storage Tank (designed by API 650) to be UV Stamped? 3
sollapalooza
13
Topic, Do PVSV and PRV on top of Storage Tank (designed by API 650) to be UV Stamped?
Thank you in advance!
API-650 Relates to the Storage Tank - I can't comment as I do not have. But basically, If the installation is the USA, and the pressure is 15 PSIG and above, then a ASME VIII "UV/NB" Code Stamped Pressure Relief Valve/device is required. Storage tank will require overpressure protection for various scenarios.
If not USA then end user and/or specification may require it (in addition to any local law or regulation).
Per ISO, only the term Safety Valve is used regardless of application or design.
No. It's not a pressure vessel.
It's am atmospheric pressure storage tank if it's an API 650 tank
Talk with these people about the rules and come back and complete this thread ....
(You are not one of those people who cut and run .... are you ????)
MJCronin
Sr. Process Engineer
Thanks!
I haven't got the time to ask proctoseal, but my colleague has already come to a decision, no UV stamp.
