DNV OS F101 - ECA
Jeldon
Chemical
BR
Hi friends! Are there essential welding variables for WPS when ECA is required?
Can a qualified WPS with the ECA requirement be used for welding a joint without this ECA requirement?
Yes, provided that the essential variables and restrictions on use of previously qualified procedures are not transgressed.
Steve Jones
Corrosion Management Consultant
All answers are personal opinions only and are in no way connected with any employer.
So a WPS tested without ECA for pipeline A can be used to weld pipeline B with ECA as long as all the essential variables are met? Thanks again.
No. That's not what was asked. Wrong way around.
Steve Jones
Dear SJones, You're very sure. I did a mess. Pardon.
But, a WPS tested without ECA for pipeline A can be used to weld pipeline B with ECA as long as all the essential variables are met? Thanks again.
Yes, provided that the necessary mechanical property restriction and fracture toughness requirements have been met in the pipeline A WPQT.
Steve Jones
Dear SJones, Thank you so much again. You have been helping me a lot.
