Dividing Manifold Flow Velocity equation
chris1321
I have a dividing manifold with X number of laterals that have a different a diameter than the main header. I know the pressure at the start of the header as well as the flow of fluid, density, and viscosity only at the beginning of the header.
What formula can help me solve for the fluid velocity at each lateral?
The "formula" should be the same for calculating the flow velocity for the same fluid at each lateral. Isn't it?
It's sound like a good exercise of the home work.
