pablochaar
- Aug 1, 2025
- 1
We have a well water system that flows through the plant and then goes back into the ground (injection well). Can we divert part of the flow to a heat exchanger using a booster pump, and then tie this back into the same header? Would this be highly illegal, slightly unorthodox or perfectly ok? On another note, what are the thoughts on using a circuit setter instead of a booster pump?
