displaying tolerances
  • Thread starter Thread starter phoxeoy
  • Start date Start date
P
phoxeoy
Guest
Is it possible to have the tolerancce displayed in the model but not in
the drawing. When I set the dimension to nominal in the drawing it
changes it in the model as well but I have to have the tolerance
displayed in the model.
Use Create Dimension instead of showing the dimension. The dimension will be independent of the model dimension.
If you want to use a model driven dimension you set the following config.pro option to not have the tolerances diplayed in the model;
tol_display no
Assuming you have your drawing .dtl file set correctly they will still show up in the drawing.
