Disappearing filenames downloading to remote client...
  • Thread starter Thread starter dternst
  • Start date Start date
D
dternst
Guest
When downloading from data server using Pro/Intralink to a remote client (laptop) the names revert back to the inital name used eliminating the link between the assemblies and drawings.
Can anyone suggest a method of downloading to client were this issue would not occur?
Thanks in advance..
I contacted PTC this morning, here's the fix:
This will link Pro/Intralink through Pro/Engineer:
Right click mouse on your Pro/E Icon
In theTarget field after the path and name of the batch file to start Pro/E add: <space>-w<name of working directory>
Right click mouse on My Computer; Properties
Click the Advanced Tab (for WIN2000)
Click Environment Variables
Add System Variable
In the variable field type PDM_LDB_PATH
In the value field type the directory in which your .proi directory is located, ie c:\
ie. /proe2001.bat -wassembly
This is case sensitive, match your directory exactly
This process will have to be done for each working directory in the .proi directory. The best way to accomplish this is by making a copy of your icon to start the Pro/E application adding the information above. Remember to leave one icon without the added information
