DIN 6784
jimp178
58
Hi does anyone have a copy of DIN 6784 chart they can send me, received a drawing from our German factory stating that the tolerance is DIN 6784.
Thanks in advance
Jimp
jim.paterson@heraeus.com
I don't think you need the standard itself. The drawing should show edge symbols, e.g. -0.3 for ouside corners and +0.3 for inside corners, meaning radii of that magnitude are permitted. It should be pretty self explanatory. I have the symbols but only as Solidworks blocks. Don't know how to convert them.
Have you tried the web site-- There are numerous sites with the standard in question
Also check the titleblock where tolerances on the drawings will be indicated
Thanks for your help there are no tolerances on the drawing only DIN6784.
If you can send me the solid works block thats will be great.
Thanks for all your help Jim
