dimensioning in drawing
  • Thread starter Thread starter shankar11
  • Start date Start date
S
shankar11
Guest
how to show dimensioning in drawing in pro-E wildfire 5.
it is somewhat different from pro-E 2.
even projection (front, top,etc) are not coming directly in pro-E 5like pro-E 2.
can anybody answer this also.
thanks
shankar
There are two questions here. I shall begin with the
second one first.
The views never displayed directly even in WF2 unless such
a template was made using drawing program. It is possible
that you were using a template made for your company.
While in drawing mode, you can insert the views while in
"Layout" tab.
The earlier "Show / Erase" is now available under
"Annotation Tab". you need to activate the tab to be able
to use the annotation commands.
I hope I have understood the requirements correctly.
select use templates instead of empty!! While opening the drawing..
