DIM question.
  • Thread starter Thread starter Vale_Bogdan
  • Start date Start date
V
Vale_Bogdan
Guest
Hi. Im new on proE and i dont know if its possible to create dims like the ones below with proE 2001. Thanx for helping.
yeah just select "ordinate" style of dimensions
Thanx. Now...i cannot manage to rotate the values 90 degrees
Go to your draw.dtl file and change the following setting.
orddim_text_orientation& nbsp; horizontal
Thanks. It worked.
Hi
If your dimensions are too close you can make jog in the dimension.
Adrian
Thanx it helped
how do you make the "jog" when dimensions are to close?
when i drag a ordinate dimension it drags the lot.. i'd rather just be able to move the 1 dim which is hard to read :)
is it possible to drag "Vale_Bogdan" 's dimensions up and down?
Do you mean if they can be moved vertically? If so ..yes its possible but all at once andonly by picking the baseline origin and moving it.
yeah thats what i meant.. yes vertically, but i dont want to move them
all at once.. i prefer one at a time. i am yet to find a way to do
this...? is it not possible?
if so that sucks... damm it i bet autocad can do it.
I tried to do this one also....no luck (or not enough knowledge). What i manage to do though is to move the dim above the witness line using a jog
no' apai mai VR fa tu mai intai cotarea in mod normal si dupa aia zici "ordinate"
Ii musai sa-ti iasa !
Alles Gute !?!
well said that man
hallo,
how can i change the dimension into DIN.
can you please explain to me in detail..because i am really new in this.
thank you
