Hi Friends:
After viewing thread 256-19870 today I am wondering if it might not be interesting to compare different methods for predicting settlements of footings on two types of soil: sands and fine grained materials.
The reason I wonder is that I have used a method I seldom hear about. I've used it since 1959 when it was publicized. My experience has found that its use has been rather close to field measurements (where that could be done). It is from an August 1959 ASCE paper of the SM division Number 2135 by B.K. Hough. It had many discussion contributions, including Ralph Peck (who criticized it). However at least one discussor compared this method to actual settlement measurements and his results show it came out quite close.
If two typical cases could be compared, by different methods, perhaps tied to some actual on-site soils and measured settlement data, it would be interesting to see the results.
I'm thinking the work in steel mills by D'Apolonia (sp) might be some data to use. I do not recall where that was published, but seem to recall the Hough method compared well with his findings.
The Hough method makes some generalized assumptions that simplify the computations, but they seem to work for me. It is included also in his second edition of his text "Basic Soils Engineering", Ronald Press Co.
It is easily set up under a spread sheet program or it can be used in a dedicated computer program with the simple 60 degree approximation for load spread. I also use it in a compiled Basic program that runs on some computers that can run DOS.
