waross
- Jan 7, 2006
- 28,256
Waross said:Feb. 4. 2010[/b]]
waross (Electrical)
4 Feb 10 13:07
I have had an idea for awhile now. It may be a bad idea. If so, can you tell me why?
Refining petroleum products seems to use a lot of energy. Much of this energy may be generated by burning hydro-carbons with the resulting release of green house gasses.
I understand that there are two basic processes used to upgrade heavy hydro-carbons to lighter fractions. Both involve breaking the molecular chains.
In what I believe is the most widespread process, carbon is produced. Much of this carbon will be in the form of carbon dioxide or carbon monoxide (which is generally burned in a boiler to produce carbon dioxide), some will be in the form of coke which is often burned to produce energy.
There is an alternate process where hydrogen is added to complete the shorter molecules. In some instances I understand that this process actually produces more barrels of synthetic crude than the number of barrels of heavy oil used as feed stock.
Now lets look at nuclear.
Imagine a nuclear plant supplying the energy needed to upgrade the heavier oils. With some plants using as much as 40% of their feed stocks to generate heat to drive the process, this alone will be a significant reduction in green house gas emissions.
Now let's use the same nuclear plant to produce hydrogen from water. We can switch over from carbon producing plants to hydrogen based reactions and gain more barrels out than we put in.
As a bonus, a by product may be free oxygen released into the atmosphere.
If thermal power plants are also phased out in favor of nuclear and renewable energy, we may greatly reduce our carbon dioxide emissions while continuing to burn gasoline for many years into the future.
An added bonus is a lot of construction driving the economy followed by jobs n the plants.
Comments??
What are the pitfalls?? (Apart from nuclear hysteria)
Current update:
Over the last few days, I have been doing some Googling on methods to produce synthetic fuels.
I was surprised at the progress that has been made, far past my original idea.
There is a working demonstration plant in Chile producing synthetic diesel fuel.
The feed stack is water and atmospheric air.
The by products are oxygen and water.
The product is synthetic diesel fuel.
The power source is wind power.
The owners of the plant?
Porsche, Siemens and the German Government.
CO2 is captured from the atmosphere.
Water is electrolized to generate oxygen and hydrogen.
The oxygen is released, and the hydrogen is reacted with the CO2.
The carbon is upgraded with the addition of hydrogen to produce diesel fuel.
The oxygen component of the CO2 combines with the hydrogen to produce water as a by product.
There are plans to greatly increase the capacity of the plant.
Why did the Germans build in Chile?
Wind conditions in Southern Chile are three times better than in Germany.
There are a number of plants around the world that are capturing CO2 from the atmosphere.
I have found three different methods in use.
One method uses sort of a combination of an electrostatic precipitater and a battery.
It works at low temperatures and pressures.
A second process uses high temperatures and pressures.
A third method uses chemical extraction.
Carbon neutral diesel fuel is here, albeit in limited quantities.
Carbon dioxide is "borrowed" from the atmosphere and then returned from whence it came.
Similar, wind powered plants but without the carbon capture may someday use sequestered CO2 as a feed stock.
Before you start to scream, this won't happen until and unless conventional sources of CO2 have been reduced or eliminated to the extent that it is safe to start releasing sequestered CO2.
Another bonus:
Chemical feedstocks will become available without dependency on Big Oil. (And without CO2 release.
Ohm's law
Not just a good idea;
It's the LAW!
