Physics_Nerd
Hi Guys
I would like to get help regarding a Diesel Day tank which will be located inside the generator room. can you please help me with the following concerns
1. I have limited space in the generator room so I am planning to Design a 4000(L) x 300(W) x 3000(H) Day tank. but, I am not sure if this
sort of dimensions are acceptable. can you please advise in this regard.
2. The edge of this Diesel Day tank will be located at 900mm from the generator. also, I cannot increase the distance as I have space constraints.
I am concerned as the generator is constantly producing heat and expected temperature of the room if 53C which I suppose could be the flash point
of diesel. is this something that I should be concerned with? can you guys advise if 900mm is OK. this 900mm is also the minimum maintenance clearance
for the Generator itself.
