Detail View
  • Thread starter Thread starter kc1876
  • Start date Start date
K
kc1876
Guest
Is there a way to blank a component in a detail view
but leave it visible in the parent view?
Version 2001.
In drawing:
DISP MODE > MEMBER DISP > BLANK > PICKED VIEW >
Then just pick you part.
The member display in the detail view seems to be driven
by the parent view. I need to blank the component in the
detail view but leave visible in the parent??????
Any ideas?????
No can do! Just make the detail, a general view and sketch the outline.
Can you make a simplified rep with the component in question hidden and create the detail using that? You'd then have to leave the general view of the simplified rep blanked. Sort of an ugly work around. Have they fixed this in the Wildfire release?
Bernie Hayden
XKL LLC
There is really nothing to fix, because a detail veiw is supposed to be an exact section from it's parent view. It is poor drafting to represent it any other way. Unfortunately most companies don't follow good drafting procedure, and you have to do what is requested of you even if it means cheating. Still I think PTC should allow us to cheat a little easier.
