design study terminated abnormally
  • Thread starter Thread starter TDPROE
  • Start date Start date
T
TDPROE
Guest
Hello everyone i've been running an analysis on a tension rod/brackets, i used a thermal load to simulate the preload tension on the rods anyway I ran a modal analysis to be sure the connections where properly working, but when i try to run a static FEA im getting this error:
The design study terminated abnormally.
The model geometry has changed since you ran the previously
run design study. Either modify the current design study to
include the other analyses it depends on or rerun the
previous study with the latest geometry.
I have no idea why this is coming up, i enabled the use of constraints and re-imported the thermal analysis data but im still getting it, any ideas why
I managed to solve the problem,
When you import a temp load from thermal you have to be sure that the structural analysis uses the current design study so you to uncheck the "previous design study" option
