HanStrulo
- Apr 16, 2021
- 117
Hi Everyone,
I would like to design a cover plate as per the AISC to a W30x173 to help with bending moment at the end of the column. But i have no idea how to start.
Can you help me with a design guideline or a step by step approach to what to check? if there are any available design examples, please let me know where to find them.
should i add the plate to the tension or compression flange? does it work with a laterally unbraced column? what are the limit states i need to check?
I have already googled the subject and i could not find something I could follow for the check.
Thanks in advance.
Thanks in advance.
