CWEngineer
- Jul 3, 2002
- 269
Trying to get clarification regarding the requirement for the Depth of Embedment into footing required for wall reinforcing terminated using standard 90-degree hook (development of Standard Hook in Tension), per ACI 318-14, para. 25.4.3 (ACI 318-08, para. 12.5).
1. Is this requirement only when you have a hook, such as that provided in sketch 1a of the attached document?
2. Or would it also be applicable when your flexure bar is hooked, but extends a greater length such as that shown on sketches 1b and 2 of the attached document?
