Deleteing Geometric Tolerances in Model
  • Thread starter Thread starter fiebigc
  • Start date Start date
F
fiebigc
Guest
How do I permanently remove or delete geometric tolerances that show up in the model? I've already removed them from the drawing but they still show up in the model. I can't figure out how to even select them.
I've attached a photo for reference.
Thanks.
U should be able to select them from top of model tree.
If your model is assembly, look them on individual parts if u cant find in asm.
Are you using Wildfire 4.0?
In the lower right corner you should have a selection filter. By default it says "Smart." Change that to "Annotation" and you should be able to select the GTOL. Then you can use RMB functionality to modify or delete it.
Alright that made me feel dumb. I was able to select and delete the annotations by changing selection filter from "Smart" to "Annotation".
Thanks.
Why is SMART not smart enough to let you pick it?
