Delete BOM Table row from a (.tbl).
  • Thread starter Thread starter laelow
  • Start date Start date
L
laelow
Guest
Anybody,
Is there a way to delete orhide abom table row from a (.tbl) while the BOM Table is in the assembly drawing without destroying the associativity of the .tbl file. When I did Table > Repeat Region> TBL REGION > Remove, it explodes the whole (.tbl) in different segments. So when I add more items in the (.asm) no extra BOM TABLE row lines appear in the assembly drawing.
Thank-you,
laelow
You mean to remove a component from the BOM?
In 2001, Table > Repeat Region > Filters > (Select the table) > By Item > Select the items you want to filtered (remove) from BOM.
Charles
