Datum reference order for composite rolerances
CTengIS
IL
What is the logical or functional reason for the ASME Y14.5 rule that the datum order and material boundary conditions need to be preserved down all segments of a composite tolerance feature control frame?
From a practical standpoint the lower segments are refinements, and it's not a refinement if one had a different basis that is unrelated to the original basis.
One can always create separate single segments if there is a desired change in basis; composite is a special case where there isn't.
In application the mating part won't have multiple different ways to interact with the given features; it will only have certain primary features to control location and orientation.
