DATA TRANSLATION from 2001 to 2000i2
  • Thread starter Thread starter bnemo
  • Start date Start date
B
bnemo
Guest
Is there a way to take data from Pro-E 2001 and save the file so that it can be read into Pro-E 2000i2 other that step or iges and keep the native associativity?
Thank You in advance..
Go to www.fawcett.com. You will need to register to find it, but Jon has documented a way to easily re-create a part in an older version.
Try with save as neutral *.neu
This is a message I got from Jon at fawcett PTC blocked conversion back to 2000i after jon's article.
I have tried this conversion and have reached the conclusion of failure.
Profit from you Profession http://skill-store.com
