R
RFR_CHASSIS_BYRON
Guest
I want to apply loads on joints on my tube-frame chassis. All recognized joints/endpoints were correct, expected joints/endpoints. The entire model meshed with no issue.
At first try, I had to stabilize the part by using "soft-spring" because the model was unstable (inadequate fixtures even though it was fixed at 4 joints).
After the model was stabilized, the simulation was ready to run.
The simulation progress gradually to about 37%, then quickly runs to 100% and finishes...only to produce an error message: "Data Not Available".
I have found few links regarding this type of error:
https://forum.solidworks.com/thread/25739
Simulation: "Data not available" Error - DASSAULT: SOLIDWORKS 3D Design - Eng-Tips
https://forum.solidworks.com/thread/88944
https://forum.solidworks.com/thread/79717
Assuming my error comes from incorrect file/result allocation, I would like guidance on resolving this issue.
Otherwise, I was hoping people with the same error could chime in, tell their story, and their solution.
