P
popi
Guest
hi all!!i need your help!
i am trying to create a post processor for dmg50 3+2 axis
cnc machine with sinumerik 810d for my master thesis.
the machine recognizes the cycles with the format, for
example, CYCLE81(RTP, RFP, SDIS, DP, DPR) for drilling
instead of G81.
In the option file generator in proe5 there is an option
for siemens 840 (motion->cycles)
But with siemens 840 the code for tapping for example is
with the following format:
CYCLE84 (15,0,15, ,21,2,3, ,.005,0,300,300, ,0,0,0,0,0)
and i need CYCLE84 (15,0,15, ,21,2,3, ,.005,0,300,300)
So there are 6 parameters that the machine with control
810 can not read.
the same is for CYCLE 83 etc, only for CYCLE81 the format
of the code is compatible.
how can i fix that??
is there a way??
or the solution is to change the FIL language?and how can
i do that??
instead of G81.
810 can not read.
is there a way??
i do that??
