N
njsavage
Guest
Hi all,
I have an extruded circle 50mm deep. I am trying to cut through the extrusion to leave sections. I am using the 'extruded cut' function hwoever I am having dificulties. 1 - once i extrude eveything else disappears. is there a way to cut the object but keep the remaining pieces? if not then... 2 - I cut the first section. afterwards i use the same extruded circle to cut the next piece along. however only the first section is left. any ideas??
i can post the sldwrk file if required.
cheers
cheers
