CUT-OUT with acurracy option??
  • Thread starter Thread starter mauricio_comat
  • Start date Start date
M
mauricio_comat
Guest
Hello everybody,
Please I need some helps. Nowadays I am using CREO. In ProE W2 when I made a cut out in an assembly, in the menu EDIT, SETUP, ACCURACY. I could select the model to take the same accuracy and properties in the two pieces(parts).
MY PROBLEM WITH CREO IS, where is the option to select accuracy?? I found the option cut-out, but IT can
I didn't understand your problem can you upload a file or a jpeg showing what's that you want. Even I am a CREO user.
Mauricio,
Go to the "file" tab and choose "prepare". In the sub-menu, select "model properties". It should be the third item from the top (in the "materials" section).
