Cut on assembly
  • Thread starter Thread starter Marek60
  • Start date Start date
M
Marek60
Guest
For two component assembly I created cut (hole) on the assy level. Here is 3 steps of my work:
1. Part #1 already has holes, created on the part level.
2. Part #2 has 2 countersink type holes created on assembly level and referenced
by hole axis of part#1 (coaxial placement
3. After that, I attached some of the fasteners to holes in part #2.
Everything looks good on the model and drawing, until I decided to edit hole distance on part#1. This is what happened:
1. Hole in part #2 and fasteners didn't updated to new position.
2. One of the holes and fasteners disappeared from graphic screen (not from tree)
3. I can't delete fasteners or #2 holes. "Delete" is active, features and parts
present in the tree, but is not deleting.
What I am missing?
Thank you for help.
regenerate assembly\drawing twice?
