Customized Tool Bar
  • Thread starter Thread starter Ariabod
  • Start date Start date
A
Ariabod
Guest
I need some suggestions on customizing the drop down menu, like I want to add the icon for "replace all" in the drop down menu which appears when you right click on a part in the assembly browser.
Any suggestions would be helpful.
You can use the Alt+Ctrl+H keyboard shortcut to trigger the Replace All command. You might be able to map the key press to a button on your mouse or motion controller, giving you one-click access to the command.
You can also drag and drop the Replace All command from the Customize dialog box to a tool bar or the Panel Bar and execute it from there.
Hope this helps.
