Customize parameters
  • Thread starter Thread starter lcl
  • Start date Start date
L
lcl
Guest
How can I customize my parameters window, I mean the way (sort) the parameters are organized (I've a lot of them that are calculated and I want them to be on the bottom of the window so I stay with the one I need to change on the top), also I need to define the width of the columns. Also I need to save this configuration so every time I open an assembly this configuration will be shown.
Any tips?
Select the column heading to sort that value. You can't set up a sort default.
