Custom Properties In IIF Statement
  • Thread starter Thread starter tim-tim
  • Start date Start date
T
tim-tim
Guest
I am trying to create a custom property that appears in the BOM to be used to help specify the material type.
Example: I have an aluminum hollow tube with some OD and ID (both are custom properties). I want to round these values to 2 decimal points and then concatenate them. So if OD was .543 and ID was .194, I would get a result of .54x.19. I have gotten thus far by doing the following:
custom properties:View attachment 2055
OD = .543
ID = .194
SubCat = "rOD@8701-P-18-836.SLDPRT"x"rID@8701-P-18-836.SLDPRT"
global variables:
rOD = round("OD",2)
rID = round("ID",2)
However, I only want to use this custom property, SubCatName, if another custom property is greater than 0. I can't seem to put the "SubCatName" in the result of an IIF statement in the equation for a global variable.
Is this possible? I'm hoping there is a simple enough workaround that won't require any changes to our business tool that we use to analyze our BOM. Thanks in advance.
