cross sections
  • Thread starter Thread starter design-engine
  • Start date Start date
D
design-engine
Guest
Anyone know if Solidworks is going to switch from adding the cross section in the drawing to the ability to add the cross section to the part instead? I think the latest ansi14.5 states that all the information must be in the part not part and drawing.Show in drawing is okay but ... you know what I mean.
No, design-engine. I don't understand.
I don't know if I can help you as long I don't understand what you mean.
Try to explain better.
My English is not the best one, I knew.
Bart,
You already have this ability using the Section View command in modeling. After creating the section view you can save it as a model view or annotation section view that is displayed in the View Palatte tab of the Task Pane.
http://help.solidworks.com/2011/English/SolidWorks/sldworks/ LegacyHelp/Sldworks/Display/Section_Views_in_Models.htm
It does however force another view to be shown as parent in the View Palette and cannot be changed.
What Bart is talking about is ProE creates sections using a Datum Plane while in modeling and not by sketching the section line on the Drawing. In ProE Sections from the model can be selected when placing a view on drawing.
Michael
Edited by: mjcole_ptc
