CROSS HATCHING
  • Thread starter Thread starter herb
  • Start date Start date
H
herb
Guest
Is there a setting somewhere that can be set to have the
hatching in a cross section set for steel? It is quite
tedious to have to change each and every hatch in every
cross section to steel from the apparent default of
aluminum.
I am also posting this to the modeling arena in case this
is the wrong place.
If you set up your material library properly you can assign the cross hatch in the material. Then you have to assign the material in the part model. Don't ask me the details, I've never actually done it.
Got it! It works perfectly.
In the part model:
SETUP/MATERIAL/pick your pre-defined material
Excellent!
Thanks, Doc!
Does someone knows if there is libraries avaiables for
proE that contain mechanical properties and also colors,
crosshatch...?
