creo vs vericut
  • Thread starter Thread starter bmwrull
  • Start date Start date
B
bmwrull
Guest
Hello I have one question. I am using creo 1.0 and
vericut 6. Now I have a vericut 7. And creo always open
vericut 6. Where I can change that ?
thanks
1.) Edit <creo installdir>\bin\proev.bat in your Pro/E
Wildfire installation to run the standard VERICUT (you
may want to make a copy of the original before you
proceed):
2. Find the line "set CGTECH_INSTALL=%PRO_DIRECTORY%".
3. Insert the following 2 lines ahead of it:
call C:\cgtech\7.1.1\windows\commands\vericut.bat %1 %2
%3 %4 %5 %6 %7 %8 %9
goto end_cgtech
(change the path to yours vericut instalation)
4. Find the line "set VERICUT_FEATURE_NAME=Embedded" and
erase it
5. Save the file.
