M
mrutzwestern
Guest
I have a weld fixture assembly with a user defined rep called “WELD1”. Originally it would, by default, create the Creo View file as the "WELD1" rep. Then I asked a guy I work with how to do multiple different Creo View reps and we started messing around with creating a new representation under the Representations/Annotations tab. Now it is only creating Creo View files for that particular assembly from the Default representation, which has a bunch of parts I don’t want in it. How do I get it to make the Creo View file from the "WELD1" representation again? And I guess since we never did figure it out, how do you make multiple representation Creo View files?
