creo regen error: (Regen failed. Highlighted segment became zero-length)
  • Thread starter Thread starter soorencreo
  • Start date Start date
S
soorencreo
Guest
hi
I create a 3D model in creo Elements/pro 5.0 (a cylinder that have 3 internal diameter in each length) then I Create a relation in Tools>Relations that it can change the internal diameter of each cylinder with a constant rate when I choose regenerate it. It is go back and it is ok until first cylinder diameter gets to zero. (I have written a relation with if that when it gets zero change the length of cylinder and do other relation but it gets this error: (Regen failed. Highlighted segment became zero-length)
Ican't do anything
plz help me someone how I can repair this error
I attach my relation program
