Creo Direct> back toPro.
As a user of both Pro/E and CoCreate, I have an interest in howCreo willadd aseamlessintegration betweenthe twoapplications. And I also have atheory on howCreo willaccomplish it.
With regards to moving the nozzle features. This is my view of how the dataexchange betweenDirect and Prois going tofunction ata basic,fundamental levelin a modeling scenario similar to that ofthe nozzle-edit we seein the Creodemo.
Any parametric feature(s) that arechanged in Directwill betracked with history, (similar to a trail file)and anyparent/child relationships affected bythe change(s) whilein theDirect sessionwill be groupedtogether according to their parent/child relationships.
Once the model is transfered back to the Pro side (from Direct), all of the top-levelparent feature(s) in any of the "groups" will be considered by Pro to be"packaged". By this I mean thatthe location of the changed feature(s) will be rememberedby the common data model, and berepresented correctly just as it was when it left Direct, but any of the parent feature(s) will not have a complete definition of it'snewly changedreferences. The feature(s) will exist as"packaged features" just the same as "packaged components" can exist in an assembly model.
I think this is the only way the data exchange between the two will worksuccessfullywithout inducing huge problems. The software isn't going to knowhow to pick every singlereference, half the time I have a hard time doing that myself!
If building in design intent is important to you, (which it probablyis for most parametric CAD users)I think you will have to manually go back into thechanged parent feature(s) and manually redefineat least some of their references.
It only makes sense that if
components in an assemblycan be placed
without references that
features can alsobe made to behave in asimilar manner in a part.
What do you allthink? I am making logical assumptions here, right?
Edited by: Richh
