Creo BOM
  • Thread starter Thread starter Prabhu1974
  • Start date Start date
P
Prabhu1974
Guest
Hi, A basic question for creo 2.0, I have more than 15 sub assemblies in an assembly and trying to make BOM and i could not get the each and every component list thro' repeat region, I am getting only sub assemblies list (&asm.mbr.name). Can any one tell the parameter to be used..
You are looking at the BOM the way most companies set up drawings. To see a full list of parts set the repeat region to show recursive levels instead of flat. Flat only shows the parts/assemblies at the current level. Recursive will show every part in every subassembly.
Thank you very much
