Creo 2 Drawing Quesion
  • Thread starter Thread starter Volunteer
  • Start date Start date
V
Volunteer
Guest
We recently moved to Creo 2from WF4, and I am struggling to find some of the commands that I used on WF 4.On a drawing in WF4 I used from the top drop down menu....View....Drawing Display.....Component Display to change models in an assembly to phantom lines. I can't find this command in Creo 2. Any help would be appreciated.
Finally found it under the view tab
....not a big fan of this ribbon interface.
Yeah, I'm not either.
They say to use the command finder, but that only works if the command has not changed names, which some have.
I'm sure everything is still there, I am just having trouble finding it. I really don't understand how all the tabs in the ribbon for the drawing are needed.
