N
nascarengr
Guest
Using Sketch/Sweep to model simple 340 deg wire clip. I need the relation to be set up to change the OD of the clip only with a fixed angle of the gap (60 deg) to show the change in gap chord length with deflection like a real deflected internal clip would change. The clip is 1.00 OD, .050 wire diameter.
Any help is appreciated!
